3000 Ford Clutch
Anonymous-0
I was leveling some ground with box blade when all of a sudden the clutch would not disengage when I pressed the pedal. I adjusted the linkage every direction to no avail. Tractor will crank in gear and it pulls just like it always did -- stopping is a big problem. If cranked in gear clutch will not disengage to put it into gear. Is this a have-to-open it up or is there some miracle cure? Thanks -- I need to get some plots planted.
does it feel the same when you push the pedal down?
I suspect the pressure plate has collasped.
or a throwout bearing arm broke.
or a broken finger, or a broken bolt in the cross shaft/release fork...
Just split the old witch and find out.
Rod
Had same problem on a MF 35
one of the clutch finger pivot pins, fell out laying in the bottom of the bell housing reinstalled pin back in business
"one of the clutch finger pivot pins, fell out laying in the bottom of the bell housing"
Had the same thing happen to me ........
