Last year the Ford 3000 voltage regulator went out. I did all the tests and replaced it. It worked fine for the past year since then. Now the generator light is back on and at 1200 RPM the voltage at the battery doesn't change at all from 12.6V. So I disconnected the field and armature connectors to test the generator and noticed the armature connection was crusty and black. The rubber boot is melted on the end, and the blade connector on the generator is crusty and black. Hoping this just needed a little sand paper to fix a corroded connection I did that but still no dice. Stopped any further tests until I get an opinion. Anyone know why that connector would look like that?
