3010 rail forks
I am woundering how to fix the rail forks. They way I understand it is ther are two pieaces of tin and have broken off. Does a guy have to splite the tractor or can I take the top floor plate and get in it there? HOw much will the parts coast? any helps would be helpfull.
Thanks brad
You will need to explain what is happening to give us more to work with,,,,I"m thinking that your probably having top shaft sychro trouble and you don"t understand what is going on, if this is what is happening a split will be needed,,and about $2500 worth of parts...
(quoted from post at 20:47:59 11/07/12) They way I understand it is ther are two pieaces of tin and have broken off.
There are no pieces of tin on the shift forks. I agree with Tim in that more information from you is required to answer your question.
What has happen is I have all the lower gears. However I do not have the high gears. I have tryed to adjust the shifting levers. It feels like it wants to go into the gear but keeps kicking back out. I hope that helps you guys out with my problem. Thanks for your help
As Tim stated earlier it's probably the syncronizers which means a tractor split is in order and R&R of trans top shaft with replacement of the syncronizers.
