3020 clutch replacement
Anonymous-0
Looks like we need to replace the clutch on our 3020. It's getting very difficut to shift and all the clutch adjustment is gone, Is this a difficult job? We have split other tractors. Any suggestions would be appreciated. Should we replace both clutches while it's apart? Will we need a pilot ahaft?
Not bad job. You can get the assembly from JD with the PTO clutch mounted and set. It is much easier with splitting stands.
It only takes about an hour to split.
Just finished putting new clutches in my early 3020D. Would definitely put in both clutches and upgrade to the newer button style clutch discs. Also would replace the rear main seal. You will need the special tool to install the seal correctly. If you can find a copy of Green Magazine July 2012, it has a great article on seal installation. Also check out the February and March 2012 for great articles on NG clutch replacement. These were VERY helpful for me even though I have all the JD and IT books. If you have an early 3020 like mine, I would replace the small flex hose for greasing the throw out bearing. Not sure if the late 3020's have that set up. Had my clutch shop set the clutch pack before picking it up. Buy a plastic pilot shaft tool for alignment from your clutch/brake shop. Mine was $6.
one thing next time i have to do a 3020 clutch i going get dave come split it for me i hr. any way i pick up last 4020 clutch i did from ky clutch 1-502-955-9173 brooks ky. you have to return core but they sent a shipping label with it 450.00 with line up tool now i now have 4 line up tools.
