3020 clutch
Anonymous-0
I wanted to know if there is anything special to watch for when doing a clutch in a 3020JD. 1968 4 cylinder gas,with dash shuttle shift(if thats what it is called)
thanks
ron
The type trans is called a Syncro-range.
Be sure and adjust the fingers with the special height tool,don't install drive clutch backwards. Also turn pto shaft while re-adjoining clutch housing to engine and DON't pull last few inches together with the bolts.
Got Lucky on a 3010 then ...put a clutch in it 25yrs ago and recall the anxious moments .. Had the dealer set the Height and listened to veteran mechanic .. went home and B-I-L put it together , turning the PTo when needed , Got down to the last 3/8 of inch ..NO GO ,, PTO was cranking motor then, so we reasoned if we loosened it a little , and tried retightening that it might go together .. went tightening a 1/4 turn all around very hard to TURN .. , SHE Went LOUD POP ! ..Honestly thought we broke something !,, all tightened easily and we coulnt wait to fire up and see if we broke something ,, as luck Would have it , It worked fine ..
