3020 diesel won't start
Lajaw
bought a 3020 diesel. Ran it for about 2 hrs. pulling a drag disk. Turned it off, went out two days later, and it won't start. Tried starter fluid, but wouldn't even act like it wanted to start. I have power to the injector and it turns over. What should I look for now? I have fuel to the filters, but haven't checked at the injector pump. I did notice last time I turned it off there was a delay in it dying. Maybe 5 seconds. Could the kill switch on the injector be messed up? Wouldn't it fire some after I spray starter fluid in the air intake?
Either should have some response. Are you sure it got into the cyls? The orfice at the intake will get plugged .Which injection pump does it have CB or DB. Might try tapping the pump with a soft hammer(lightly) to see if the plunger is sticking.
Is it 12 volt or 24 volt. Are the batterys good and charged up. Does it have any diesel in it. Ether should start it but when mine did start with ether and died in 5 seconds I had to bleed the air out at the filters and injection pump. That is what I would check. Good Luck!!!
I was always told to look for the obvious first. You say it didn't want to shut off immediately before. Is it possible that the fuel control rod to the pump has jumped off? It may be catching the pump just enough to shut off but not engage the throttle arm to open the metering valve. It may not be this at all but it may be worth checking. Mike
I'm not a diesel man. Are you referring to the injector pump? I'm sorry, where would I access this fuel control rod?
I can't say for sure that the ether got to the cylinders. I sprayed it into the air cleaner. I tapped on the injector slightly and no improvement. I'm not getting any smoke, nor any sign of life with the ether. Is there any other electrical component other than the injector that I should be made aware of? There are no safeties on this tractor that I can find. Do you know of any?
This rod will be on the inside of the injector pump between the pump and the block. It is possible that the rod has come "unsnapped" from the ball on the throttle arm. If you look back there it will be obvious. If the rod has come loose it will simply snap back on. If it doesn't snap then some repairs will be necessary. Mike
