FarasAutoRepair
Have a 71 3020 gas tractor and after running it under light to medium load for 2 hours I shut it off. After a couple hours come back to the shop to where it is parked and find that there is a spot of oil under the breather tube about the size of a deck of cards. Is that expectable? I literally just reset the valves and new plugs plug wires and new coil and electronic ignition and set the timing. New carb and radiator also. When the new plugs went in and after setting the valves I also did a compression test and it came in around 150 on all 4 cylinders. Also just changed oil in it using 15w40 oil.
Didn't know what your guys thoughts were as to if there is something going on or if that is ok and nothing to worry about. Tractor has 7700 hours on it but somewhere around 4000 hours it had the head gone through. I do not know as to why just the head and not an in frame but that was what I was told when I bought the tractor.
