3020 Gas weight
Anonymous-0
How much does a John Deere 3020 gas weigh. Have only seen pics. No rops. 2 front weights. No outer wheel weights(don't know about inside). This tractor is on auction and my dad is interested in it but don't know if he can haul it. Thanks.
external_link says a 3020 Gas has an operating weight of 7,695#. They also say with weights, it could weigh about 9,585#. Hope you have a strong trailer.
My trailer has two 5200 lb axels. Total load of 10400 lbs, minus weight of the trailer itself. I'll have to weigh the trailer. Thanks.
According to JD Waterloo Tractor Works book, 3020 gas with w/f weighs 7418. F.O.B. Waterloo. With power shift add 259. Depending on size of tires could add 63 to 180 more. 2 side weights add 155. Double front weight add 320. List price when new was $7162.
Fluid in the rear tires will add 550 to 700 pounds per tire, 1100 to 1400 pounds total. If you email or call the auctioneer they should know if it has fluid. They should also know if there is someone near their location that can remove the fluid for you.
I haul my 3020 0n a 14,000 gvw. trailer but mine has a 148 loader and fluid in the rear tires 15.5 x 38 I figure mine is pushing 10,000 lbs emty weight haven"t really had a chance to put it on a scale and verify that.but I would guess a 3020 at aroun 7.000#
My 3010 gas narrow front with loaded 13.9-36 tires and one full slab weight in the front weighs 7400 lbs that should give you a good ball park figure
