3020 load shaft seals
I'd recommend this place. http://www.bolingmachine.com/load-control-shaft-seals.html
Pats parts stores, bushings with o-rings & seals are as good quality as boling & a fair amount less costly,.. and the quad - ring seal from JD fits them & is a better seal than solid rubber seal.. Only # I have is 219 326 6543 don't know if it works anymore... Or just google Pat Hannon , La Porte IN.
I put a set in a 4020 and will never use anything else.They are a longtime fix and a much better design than Deere.I have changed many sets over the years and these are the best and if you ever need to replace them they use a Deere seal off a 7000 series tractor that is put in their holder.
