310 oliver engine
PCH
Is there any automotive engine rods that will work with an offset grind of crank? Or would it be better to have them built?
The cheapest route would be either the 2.25 crankpin 88 rods or 2" 77 rods. I think if you try to stroke it more than that you will have clearance problems with the cam. If your running high rpm or compression the 2" journals might not last long.
