Hi,
I would like to inspect the oil pump of my little 330 and I have problem removing the oil pan. All the bolts are out, I remove the 3 big bolts under the middle of the tractor where the ball assembly is attached and also removed the tie rod. I jacked up the tractor from the middle section so no pressure is on the from axle. The wishbone got lower by maybe 2 inches but I still can get the pan out as there is not enough space between the oil pump and the wishbone.
I am missing something?
Thanks,
Lecoq.
<image src="http://forums.yesterdaystractors.com/photos/mvphoto28078.jpg"/>
Thanks,
Lecoq.
