350 hvdraulics
Anonymous-0
I have an IH 350 utility. The hydraulic oil gets in the crankcase. Is it the hydraulic pump seal? I would appreciate any advise before I start tearing it apart.
My 2606 seems to make a little oil as well. But it isn't the milky looking stuff in the tranny. I can't tell the difference from the 15w40 I put in there. Clean oil even after an oil change as it doesn't seem to get black all that fast. Maybe the engine heat gets rid of the moisture in the oil. I have enough blowby that it should be burning a lot of oil. As it is, it just maintains at or above the full mark.
Question: Would a leaking pump seal affect the pressure output of the pump and maybe affect my power steering which isn't very good? Thanks.
