Paul 300 U
I confess upfront that I'm probably being a bit lazy with this problem. This tractor has had it's share of issues but I've made progress on a number of them and have been able to keep cost under control. One issue it has not had is starting. 12 volt system. Pull choke, about 20% throttle fires up pretty quickly.
I got it out of the shop after transmission repairs and I was surprised that it needed a jump after 4 or 5 brief cranking cycles. I wrote it off to sitting for several months. Now, out of the last 10 starts over the last 2 months I've had to jump half the time It's been cold and I haven't had a lot of experience cold starting this tractor. It's now above 40 degrees and no improvement It's flooding then dripping so I know at least gas is getting to the carb. I've pulled the plugs after cranking and they appear dry. I've also put about a tablespoon of gas oil mix in number 2 and 3 plug and that seems to help but not always. Also the engine doesn't crank as fast as I think it should whether jumping or starting off a freshly charged battery. Once the engine is warm it starts right up. My question. Do I rebuild the carb or attack the slow crank issue. Unfortunately I usually only get an hour here or there to work on this tractor so Im hoping to attack in manageable chunks of time. Currently, I need to move it out of the shed into my garage so I can once again repair the broken power steering. Thanks Paul
