37 JD D Wheel weights
Anonymous-0
Can anyone tell me if a F&H DP2628 rear wheel weight can be mounted first on the 28 inch cast center and more DP2628 weights can be used to form the stack or do you need to start with a D2628R first then the DP 2628 weights?
You have to use the smaller diameter JD weight or a foundry equivalent of it as a starter weight and then add the F&H. On a 28" I"m not sure you may have to add two or more? We couldn"t make the F&H larger one go on first on styled D with 30" without doing lots of grinding on outside first but made it work so no way it"s going on first on the 28" I wouldn"t think. What was the W number weight you were asking about earlier? Just a foundry weight or what does it look like?
Pics of how they fit on Parts & Pieces just type in the weight numbers. Here is one pic.
