grandpa Love
Got this back in December. Seller said it was loose last year. Well........it's stuck now. Drained oil, 1 quart of oil ,5 gallons of water. Pulled plugs filled with ATF. Sat for a couple months. Nothing. Pulled head, cylinders had water in em. Uggggg. Filled with some penetrating oil, been setting 2-3 weeks. Today took motor off and flipped it over. Will let it soak from the bottom for a while. If that don't work I will attempt my first rebuild.
Well you say your first rebuild, you could have not been luckier on the position of the pistons when the engine stuck. You can remove all rod caps where it is and go to work on driving the pistons out. Sometimes they stick where you cannot get the caps off without the engine turning.
(quoted from post at 18:11:48 03/31/19) Well you say your first rebuild, you could have not been luckier on the position of the pistons when the engine stuck. You can remove all rod caps where it is and go to work on driving the pistons out. Sometimes they stick where you cannot get the caps off without the engine turning.
BE SURE to verify that all rods, rod caps, and main caps are "match marked" as to where they go and in which orientation BEFORE beginning to remove them and look CLOSELY for any shims that may be installed (this IS an Alice Chompers, after all) and if you find any, keep them in the original location.
One of the nice things about the allis motors is you can pull the crank without having to remove the pistons. Then you can work on each one individually. You might find out that only one is actually "stuck".
(quoted from post at 14:16:03 04/01/19) Is that part of the piston skirt beside the number one rod in the large picture??
It looks like the lower portion of the sleeve to me. The crank throw for the #2 hole cuts across it making it look like something is broke.
AaronSEIA
