I would imagine that the Series II signification is for the last years of production.....otherwise why go to the expense of the decal signification?There are two manuals listed in the parts section here;1983-1985 and 1987-1990(series2) $29.95 ea.
His tractors identity crisis has been solved in earlier replies you evidently skipped when reading this thread. You were even one of the ones replying with information. Do you happen to know anything about the current question he is asking about concerning his starter in reply 39?The series II which has a decal right where your Series II does, signifying that yours is a Series II and the latest models of the series manufactured in the end of the 1980's as another guy has indicated herein. You have the upgraded transmission....don't recollect what they called it nor how it operates. As stated previously, mine are 8 speeds, 4 gears in each range, shifting sticks on top of the tranny. Why is the model year important to you? You need to order parts? What parts?
I have removed few starters over the years.....Obviously the first thing is to disconnect the negative battery terminal. The Fords starters (recalling) use 3 screws to mount them to the main casting. An extension with a socket and suitable ratchet wrench is how you get to the hidden one on the back side....extension has to be long enough to get the ratchet out behind the starter main body.i have returned with starter problems on my ford 3910. the solenoid for starter is bad. should i remove starter to replace it.the solenoid is mounted on the starter thanks. Don
Thanks for the heads up. Hope the other post I just finished solves his problem.His tractors identity crisis has been solved in earlier replies you evidently skipped when reading this thread. You were even one of the ones replying with information. Do you happen to know anything about the current question he is asking about concerning his starter in reply 39?
I've had too many Fords to remember which did what but my 3910 is on the range lever (right side lever) where earlier Fords like my 2000 has it on the left....forgot which the 3600 has, probably tracks the 3000 method as the 3600 is just an upgraded 3000. Once I had a Ford with an intermittent switch and found that the shift lever protrusion, designed to close the switch when that shifter was in N, didn't fully depress the ball bearing that activates the switch. I think I put a flat washer under it to raise it up so that the shifter could push the switch down far enough to make reliable contact.Before I pulled the starter to replace the solenoid I’d check the neutral safety switch connections first
On the 2000 I mentioned, I had a neighbor that overhauled them for a living in his shop on his farm. When I went there to get it, he put it in a vise and hit the switch. Jumped to life. I was really disappointed when almost immediately, the same problem I experienced earlier returned.I had the little copper strap between the starter and the solenoid get loose, pitted, and sooted. Being hidden on the back side of my starter, I chased a lot of different issues before I found what the problem was. It would work for a week, then not work for a day or two. Very intermittent I tried 10 different things, always thought, oh now I found it…
Finally it gave trouble while in a dark shed and I saw the sparking. Took longer to take off and put on the nearly hidden nuts than it did to polish up the ends of the copper strap and seems to be working since. I think, oh now I found it….
But there are 100 things it ‘could’ be. If I need the tractor to work I take the starter off and take it to the one remaining machine shop in town that still rebuilds starters and generators. Then it’s all brought up to good shape and is dependable for years again.
Paul
75424what part of texas do you live texas mark. you sure know a lot about old ford tractors thanks for all your input.
Don burden cedar hill texas
Good luck Donam truly thankful for all that have helped in this model number chalange.it runs great. at 93 yrs of age and no cell phone my curosity is still present .
a friend has repaired many problems with my 3910. i can barely wait to mow again
Thanks to all
Don in Texas
