north puller
Lets compare a few engines. Lets take a Farmall M, a Massey 44, A Mini UB, and a Case DC. Any other 4 cyl examples are welcome too.
Now lets build them all exactly the same size. 4.5" bore by 6.5" stroke. 414 cubes.
Lets make them all 10:1 compression.
Lets give them all a pulling cam, designed to make power at rated speed with a high idle limit of stock. The Farmall has the advantage of having the most RPM, while the Case has the least.
Next we have heads. Lets compare both stock gas heads, and any replacement or aftermarket head available.
I would assume that at this point, cylinder head air flow will determine the strongest engine.
Or is there something else that makes a difference? Manifold, carb, ignition???
Cost of the build aside, whice one has the advantage and why? Which can make the most power on the same number of cubes?
Just a little conversation. Not meant to be a brand war.
