TractorDad3
Proud of myself for getting this out, cutting bolts and soaking others for weeks. Check out the wear on this, which looks like it wasn’t the first repair. Fortunately the new pin screws into the front bolster properly and wiggles only a hair. On that note, aside from a bit of anti-sieze, should I spot four points of the end of the pin with JB Weld when installed into the bolster with axle and bushing to eliminate that little wiggle? Four points could be hit with a grinder later when the next pour soul acquires this beauty when I’m done with her.
Thank you for your thoughts. I’ve read through the archives and I am not going to take off the bolster to weld it up as the pin seats pretty well
