400 chevy engine head info
Anonymous-0
I bought a 400 chevy engine and was wondering what size the heads were. 2.02 or 1.94, it was out of a station wagon or something, nothing high powered probably. And the man also said it had electronic igniton, what year would that possibly be?
hoss helped ya on the valves, as to the electronic ignition it can have one, i had a 1977 chevy 4x4 with a small block 400 in it, it was electronic ignition, ran it untill the body literaly rusted off of it, but the engine never had the valve covers off still ran great when i sold the truck to a wood cutter
202 valve heads didn't come in 400's from factory.HEI came out in late 73 I beleive.Someone correct me if I'm wrong.
they made 400's from 1970 till 1979.
only year that was different was 1970, it had 4bolt main caps. the arguement still excists today whether they are better or worse then the 2 bolter's. I've heard enuff from multiple engine builders to use only 2 bolt blocks. we install 350 connecting rods when we rebuild them, you have to buy different pistons, to make them an even better motor.
I have not found anything listing 400 heads with 2.02 valves so I cant say they did or did not have them , but it looks like they did not .
Looks like you could get points and hei in "73
Mortec"s
400 block casting codes:
330817.....400...72-80...2 bolt
3951509....400...70-71...4 bolt
3951509....400...74-80...2 bolt
3951511....400...70-73...2&4 bolt
Nasty Z28"s
400 block casting numbers
400 1970-72 4.126 (2.65" main) 4 bolt
400 1973-80 4.126 (2.65" main) 2 bolt
1973-76 3030817 400 - - 2 car, truck
1973-80 330817 400 150 180 2 car, truck
1970-80 3951509 400 150 265 2/4 car,truck
1970-73 3951511 400 255 265 4 B & G body
I have a 4 bolt 400 under a work bench that I am sure is not a 1970 casting . It was a 71 or 72 cuz I could have sold it for big bucks last summer to a guy wanting a 1970 casting date for his restore project .
Don"t believe everything you see on the internet , I see lots of conflicting info by reputable sites (mortec ,Nasty,others) not that they are trying to be misleading .
I successfully ran 1.94 350 heads on a small block 400 in a '76 pickup 'way back when.
It would probably work to run double hump 2.02's.
Why waste your time on an old set of possibly cracked heavy cast iron heads with restrictive ports and poor combustion chamber engineering?
They sell a matched cam, manifold & cylinder head that are designed to work together.
Street Legal & Street High-Performance Heads
Edelbrock Performer RPM S/B Chevy
* Designed for 302, 327, 350 and 400 c.i.d. engines up to 1986
* Heads with 64cc combustion chambers improve performance and retain stock compression ratio on 1970 and earlier small-blocks
PERFORMER RPM WITH ANGLED PLUGS
Chamber Size Intake Port Size Valve Sizes (in/ex) Bare (single) Complete (single)
70cc 170cc 2.02"/1.60" #60619* #60719*
64cc 170cc 2.02"/1.60" #60949* #60999*
PERFORMER RPM WITH STRAIGHT PLUGS
70cc 170cc 2.02"/1.60" #60639* #60739*
64cc 170cc 2.02"/1.60" #60889* #60899*
POLISHED PERFORMER RPM WITH ANGLED PLUGS
70cc 170cc 2.02"/1.60" N/A #607119*
POLISHED PERFORMER RPM WITH STRAIGHT PLUGS
70cc 170cc 2.02"/1.60" N/A #607319*
64cc 170cc 2.02"/1.60" N/A #608919*
> To use stock rockers on Performer & Performer RPM Chevy heads, .100" longer than stock pushrods are required.
> Use Head Bolt Kits for easy installation.
> S/B Chevy heads may not be used on engines with less than 4" bore (262, 265, 283, 305, 307 c.i.d.) except with cams having less than .450" valve lift.
If you use heads that weren't originally on a 400, make sure you drill the steam holes in the heads, you can use a 400 head gasket as a template. If you don't have them there's a high likelyhood of overheating and a cracked block.
