DK44H
I was wondering if anyone could tell me approximately what my 400 weighs. Its a narrow front with 15.5x38s with fluid in them. It doesn't have any wheel weights on or a fast hitch. It has the PTO and hydraulics. Any ideas? I haven't been close to a scale so I'm lookin for some help!
Also, I was wondering which hydraulic remote levers operated which remote? I have a hole in the line that goes to the rear outlet and I bought the tractor with that set off, so I haven't been able to use any hydraulics. Thanks!
Of the three levers the outside one would operate the rear then middle is the right front and the inside is the left That is how mine is.
If the rear tires are filled to capacity, that will add approximately 700lbs per tire according to ballaststar.com's chart.
I just weighed mine a few weeks ago. Gas 400 no weights. Has hyd and 14.9x38 tires it weighed 6350 lbs. I weigh 260. So just the tractor is around 6100. So if the fluid is 1200-1400 lbs your looking at around 7500 lbs.
