Anonymous-0
Have not looked at it yet but what would cause 4000 3cyl gas tractor to run only corectly for couple minutes than miss an only run with choke on? Tractor was just overhauled an person could not get to run corectly even after cleaning tank lines an carberator more than once.Have advised him to remove gas cap in case cap would be plugged. I believe carb does not have load adjustement.
Well, a bad switch caused a similar problem on a JD 2010 I had one time. Switch caused intermitant ignition, also caused points to burn out faster.
KEH
