4010 will not go in reverse
Anonymous-0
I am looking to buy a 63 4010 from a guy that says it is in good shape but will not go into reverse. Is this a linkage problem or are there more internal transmission problems. All the other gears work fine. Any help would be appreciated.
We had trouble with our 4020s tranny hauled it do a dealership and all it was was the cable.If someone can move the shift lever and have another person watch to see if the levers move on the lower right side that might give you a good idea if it is a shifting cable or not.
You didn't say whether it is a power shift or not
but I had a 3020 power shift that I had to keep the shifting cable lubed so it would shift right
and some times move shifter side to side to get it to work.
I"ve got a 4010 and it"s probably a 90% chance it"s in the linkage. "Just got to start tracing it down. You should have a reverse in both the 3rd and 5th gears. Is it out in both? If it "feels" like the linkage is engaging in both gears, but still won"t move, you"ve got other problems.
The synchro TRANSMISSIONS themselves are ALL are capable of the "FAST" reverses. IIRC, DEERE made an update locking them out at the shift quadrant. Some may not have gotten the update.
I've got a 4010 and they do have a reverse below 7th gear. As others have said there is an overwhelming chance something is up with the shift linkage. One time we had a cotter pin come out of a clevis pin. It can be that simple, sometimes.
As far as I'm concerned it is one the best tractors ever made.
4010 also was notched for the 3rd reverse There is also a forth reverse in the syncro 3010/4010 and 3020 /4020 even in 4620s Im not sure about 5020 but I think there also But to get the forth reverse there needs to be a notch cut in the dash itself below 8th gear.
Mine has a 3rd reverse too, but the decal that labels the gears says that there isn't one. I think of it as "the bonus gear".
my 4320 had reverse problems as well as other gears. we had to change the synchro cluster pac and a bearing on the end of that shalf, and every thing works as good as new
