4020 Diesel melt down
Anonymous-0
The wiring melted down that crosses the bell housing .. After finding the culprit and replacing same, There appears to be no other damage to wiring ,,However I cannot get any Electric Through Anywhere , Is there A fuse or circuit breaker that I should Check ? Thank you
I wish i could see this rig, they came out with 24 volt and some have been changed over to 12 volt and no telling what is the problem. The plug in that is under the hood and in front of dash can give you fits, unplug and have a look see. there could be 2 circuit brakers mounted beside the starter solenoid. Say, do you have any oil and charging lights ?
Thanx Lonzo for Your Concern .......4020 is now At STABLE 1 ,A .O K . Loose wire hiding from me,, Got a converted 12 volt system now for 2 years , 24 volt was a real NIGHT MARE
