veachjj
I have a 4020 gas with the selenoid in the carb. The selenoid is leaking around the wires. My question is can you eliminate the selenoid or not? If so how,if not what will happen? They want $285 for new one, and are looking for some different options. Thanks in advance for any info. Thanks
Just a question about the solenoid on a Zenith carb. Does it also act as the hi side adjustment for the carb. I have a 4020 gas and see no adjustment for the hi side but the solenoid. My tractor is running a little rich and I was going to make that adjustment but can't seem to find that answer in my manual.
Mark
my 3020 did the same thing solinod leaked but it also had a screw for main jet bought after market t handle jet for about 40 bucks
You can change to a normal load screw. That solenoid has a screw in it for load ajustment so you can't just remove it. The function of the solenoid is to stop diesiling of the engine when you shut it off.
