Had my transmission leak fixed on my '65 Powershift 4020. The tractor would leak from the bell housing area anytime I ran the PTO, but not running or pulling equipment without PTO operation.
Repairman found what he described as a cracked plate in the 1st clutch pack letting fluid press against a seal?. Leak is gone, but within about 20 hours of use with 15' bushhog and round baler, the pto is spinning again while off. Until I had the tractor split, the PTO was rock solid as I had the brake lining repaired about 5 years ago. I always use an over run clutch on the pto.
I did NOT look at the PTO for movement when I got it back to the farm. I always turn the tractor off to hook up the PTO and hydraulics. I checked under the steering wheel and the linkage is all in good shape, tight and free of debris. The PTO check plug reads out 150 psi when the PTO lever is engaged and 0 psi when turned off.
When I got the tractor back, I drained and refilled the transmission with 15 gallons of Hyguard fluid. Filters looked good and screen had very minimal debris on it. Nothing I would worry about and no metal shavings I could see in the drained fluid.
I do remember shifting from 7 to 8th gear on the road after changing the fluid and I heard what sounded like the 3 point arms clacking against the wear plates behind me. Again, I did not look at the PTO, but I do think I had it running when I was test driving the tractor.
Any ideas? Would splitting the tractor to the 1st clutch pack affect anything with the PTO? Would I have damaged anything shifting from 7 to 8th gear with the PTO running?
Thanks for any advice you could offer.
