Have a JD 4020 diesel synchro range (serial #201,000-) that we overhauled this past winter with JD parts. It received new pistons, rings, sleeves, and injectors, and we also had the head machined and cleaned. The tractor starts quickly and runs well but with a lightly loaded wagon behind the tractor (maybe 4K lbs) the engine will run away a bit down a hill, with the throttle at idle it went up to 1700 rpm on me but then at the bottom on the hill would then slow to an idle again. The valves and seats where not replaced in the overhaul and from research Ive done thinking this could be the issue? Also read that the fuel pump could be the problem but oil looks normal and fine. If anyone has any insight of what to check or what the problem could be I would very much appreciate the advice!
