4020 with Schwartz front end
Anonymous-0
I have a 1965 4020 that has a Schwartz front end under it. I need to replace the tie-rods but the center steering arm is worn were the tie-rod goes through and bolts, from the old tie-rod being bad and wallowing the hole out. Would this be a John Deere part or a aftermarket part that came with the frontend? I do not see any kind of part# on it. After I get this repaired what is the proper way to align the frontend after replacing the old tie-rods with the new. Thanks for any help you may be able to provide.
Mark
Thanks for the reply, What's the cost and how long would it take to get? It's hay season here in Oklahoma I my need to try and get this one machined if a new one is too far off. Please get back with me and I will figure out something.
Thanks Again
Mark
Mark,
After new tie-rod installation,measure center of tire to tire,front of tires & rear of tires even with spindle. The distance in the rear should 1/8-1/4 greater than the front therefore you giving toe-end.
