Central Illinois
I have a 1941 Farmall M that I am just starting on. The owner wants me to get it running again. The engine has been stuck for at least 15 years and the tractor hasn't ran longer than that. At least it was in a shed. The engine has a lot of rusty crud in it from old oil sludge and condensation. It's the worse I have come across. When I put the tractor in gear and rock the tires I can see the fan slightly move back and forth so I know the crankshaft is trying to turn. I removed the rocker arms and pushrods. Then I removed the cam follower cover and found a real mess. All of the cam followers are rusted in pretty good. My question is have any of you ran into this and what did you try or do? I am planning on cleaning the area as best I can and using some pb blaster. I have a picture so you can see what I am talking about.
