420 Deere is alive
grandpa Love
Cranks and runs fairly good. Occasionally it pops a bit out the exhaust. Maybe twice a minute. Tried adjusting the carb....... Not sure if the jet on back/ bottom is correct. It's short and when screwed all the way in it doesn't close the flow off, we took the part the jet screws in out and you can look in the holes and see the needle point just coming into view.... Well back away from the small hole going to the bowl. Will flail at it a while. Pto works. 3 point works. Good oil pressure.
Sounds about right for an engine they sold 2 cylinder off to Oliver. Other wise they would run smooth like the rest of the tractors around.
But the Oliver still couldnt keep up . And they always looked sickly like they needed just a little more fertilizer
