420 tachometer question
lynn herring
my 420W has an old tach installed in the dash. There is no tach cable and there is a (plug),looks similar to a freeze plug in the block, where the tach drive gear should be. I'm assuming the engine was replaced sometime ago with one that never had a tach installed. Presently trying to restore it. My ques. is, what is the best way to get this plug out, without dropping the oilpan? Thought about punching it on into the block & letting it rest in the bottom of the pan, but i'm not sure that would be safe. Suggestions would be appreciated.
drill a hole into the middle of the plug big enough to put a small file in, and file it both ways(up and then down until you get to the casting) until it can be just pulled free with a needle nose pliers.
Maybe the dash was replaced.It would be a lot easier to replace the dash with one that didn't have a tack.
It may just be a freeze plug ? just use a sharp pointed tool and pierce the center and then drive the tool in farther and then just pry it out. Same as removing a freeze plug.
forgot to include in original post; I've had the tach rebuilt & and trying to get everything rehooked-up to use the rebuilt tach., new cable & drive gear. thanks for the suggestions.
Lynn there are threads behind the plug if you punch it you could hurt the threads and not get the tact drive in , if you drill it you might get shavings in the pan ,your best bet is to drop the oil pan remove the distributer use a long rod with tape around the end and tap it out from the bottom,it should come out easy
