420T without engine stamp
I bought a 420T today it"s a gas tractor but there is no engine number where it"s supposed to be (under the generator).Are some not stamped from the factory or what?Thanks for the help!!
Your tractor could have had the block replaced with a replacement block at some point in its life, it the block was never installed in a tractor from the factory it wouldnt have been stamped, if your tractor has a legit serial number I wouldnt worry about the engine number, if your tractor is missing the serial number and you have no engine number, then there is no way of determining what your serial number is. Hope this helps!..------ ------
Thanks for the advice,the tractor has a good tag.I will also clean it up some more and look harder for the number.Thanks again,Gary
