4230 JOHN DEERE
Anonymous-0
My father has a 1974 4230 JD that requires starting fluid every time you start it. I am afraid that eventually he will put a hole in the piston.Does this model suppose to have a glow plug? Any comments or suggestions would be appreciated.He is 80 yrs old and it is dangerous for him to spray starting fluid as he is cranking the starter. Thank you
The 4230 does not have glow plugs. It should not need starting fluid except in cold weather. Even then it is better to just plug in the block heater instead. There is something not right there. Injectors or pump.
The 4230 was noted for being a hard starter. I had one and needed to use start fluid any time below 60 degrees. Brand new engine starts some better but as soon as you get a few hours on it you need to give it a snort. Deere mech. told me it is because the rings were placed to low on pistons. 40 series started better 50 series better yet. If dad has to use fluid below 60 degrees yes that is normal. If needs it at 80 degrees then that engine must really be wore out and tired.
The 4230 has a reputation as being hard to start when cold. Might be that the compression is a tad low, made worse by grinding valves instead of replacing valves and seats or using too thick a head gasket.
Gerald J.
a few pumps on hand fuel pump will help. While cranking turn steering wheel back and forth, this will relieve pressure from Hyd. pump.
I have one and it too needs a snort in any weather where you have on a long sleeve shirt but it doesn't need much then it runs fine. I try to use just a little spritz, not enough to make it clatter.
The roosa master pump has limited excess fuel delivery at cranking speeds due to nature of design. In other words it is difficult to get a good cracking of the injection nozzles for good spray. Just like testing nozzles on the bench, if you pump tester slow you often have poor pattern but hit it hard with a lot of fuel and it really pops. On the in line pumps, there is a lot more fuel available at cranking speeds. Some pumps use a increased fuel device operated by engine oil pressue so it is deactivated so to speak once engine starts, or if you have to crank a long time to start. I am not sure if the 42 uses a lower comp ratio than the 44 or not. Piston height over block is critical along with valve protrusion and recession. Placement of top ring would also have some effect. I do know that a lot of Deere Mechanics used the M & W pistons when overhauling the 4020's for better starting. I personally never had the opportunity to measure them up to see if the height was greater or the bowl size was smaller. IH went to a smaller bowl size on the german diesel engines and made starting and cleanup much improved. Most service manuals are very poor on giving the piston protrusion over block specs. A engine rebuild shop does have access to this information along with the length of connecting rod center to center dimension which is also critical.
(quoted from post at 22:25:33 12/15/09) My father has a 1974 4230 JD that requires starting fluid every time you start it. I am afraid that eventually he will put a hole in the piston.Does this model suppose to have a glow plug? Any comments or suggestions would be appreciated.He is 80 yrs old and it is dangerous for him to spray starting fluid as he is cranking the starter. Thank you
The rings and a piston or two may already be smashed.
My Father had a 4230 that wouldn't crank and start worth beans. I checked with a volt meter and found 2-1/2 volts drop due connections and cable that looked good but were actually junk.
The hydraulic pump de-stroker costs a whole $15.00 and makes a world of difference. Tweaking the steering wheel back and forth is mickey mouse.
Good to hear about somebody interested in a block heater instead of asking how much ether is ok.
http://www.phillipsandtemro.com/coldStart/engine_block_heaters.asp
AR96625 FIELD INSTALLATION KIT 1 -XXXXXX (A) (MANUAL DESTROKE) (SUB RE13271)
