We have a late model 4230 with excessive fluid
leaking through the steering valve. We had the
same thing happen on a 4240 some years ago and
have the valve that came off that tractor. When
we inspected the old 4240 valve, the body and
piston shows significant scarring on both parts.
Does anybody have experience rebuilding these
valves? Anything we can do to keep from spending
the $1100+ that JD wants for a new one?
When you look at the service manual and flow
diagram it appears that there is a location along
the piston that you could put an o-ring and backup
washer to keep the high pressure oil separate from
the control oil.
Another alternative we thought of was boring the
housing to some 0.030 or 0.050 inches larger and
rebuilding the piston to fit...but I'm not sure if
that saves much $$ and how reliable it would be.
I know there are some pretty slick fellas on here
with all sorts of hydraulic experience on these JD
tractors, any help would be most appreciated.
Thanks.
the control oil.
Thanks.
