Hello, yesterday I had a call to look at a 4240 that is making hydraulic noise. Owner put brand new hydraulic pump and new updated pump shaft. The tractor hydraulics are working fine, however the 65 years old owner is complaining that the steering wheel vibrate.
There are some noises in the steering wheel from low idle to 1600 rpm. The vibration happens only if oil is hot. Loosening the steering wheel cap helps it goes away but does not solve it... You can only hear the noise with the door shut: a 4020 owner would not complain.
I put another steering metering valve but this chlanged nothing. The valve came from a 4230 and I had to swap fittings. In the process I managed to put the check valve equipped fitting at the wrong place. On restart, steering was not working, but noise was, completely gone.
I put it back together right and noise is still there.
I noticed the line going to the attenuator on LH side chatters, the one going from attenuator to cab chatters less.
Do you think it is worth trying another attenuator? Do you think that steering block is leaking? Steering is working so wel' I doubt it.
I did not check the priority valve because I had forgotten where it was... But I think she could well be the culprit.
This is a difficult case because Tractors is working very well, nothing hot after hours of use...
Thanks!
Thanks!
