I recently purchased a 435 Diesel tractor. It needs to be overhauled as it is worn out and it wetstacks. I have done some searching and found out that there are some updates that need to be performed to the engine to make it better. I have some questions,
If I buy connecting rods for a 3-53 will they be the piston spray type?
How can I find my local Detroit Diesel dealer?
What size injectors can I go with if I swap to piston spray type rod. I do not want it to smoke at any engine speed.
What is the difference between C series injectors and N series?
Will I need to add an oil cooler with any of these updates?
Can I use a rebuilt oil pump out of a 3-53 to create more oil pressure?
Are there any other updates that I should be aware of?
What is the estimated cost of the rebuild?
Thanks, cooop
Thanks, cooop
