44 rear end
I have a mase harris 44 and the rear end leaks ater driving. it comes from two litle holes on botttom of the rear end. the holes are one on each side right below the the breaks and the clutch petals. what could cause this?
Leaks below brakes are usually caused by leaking differential shaft seal behind brake drums, or plugs at end of shaft. Need to remove brake unit to find where leak is from.
Hi,May not sound like good advice but most owners
over the yrs used to leave the oil level down an
inch or two below the check plug. Still lubes all
the parts and less prone to leak. Chuck
