Jaxon Guthrie
Here is the full story, yesterday I just got a john deere 4430 quad range running that was sitting on our property and it drove fine i ran it up and down the road through all of the gears,(note- the pto is spining all the time even with lever off) once i drove it a little i hooked it up to the bale fork and the 3point was miserably slow down and up, i went to go move some bales and by the 4th bale the 3 point barely moved, i started heading back to the farm and i could barly go forward as i was trying to figure out what was going on i decided to turn on the pto lever and when i down shifted from 2 to 1 the lever kicked out.....with that i shut it down..........i let it cool down for 2 hrs or so and i went to try to move it again and it moved fine but the 3point was still slow,the pto was still moving with the lever off and when the pto lever was on, it still kicked out when you downshifted..
Can someone help me understand what the problem is, something to do with pressure because it only happens when oil is warm and thin
