445 jetstar.....
I have a 445 jetstar MM that I got last fall. At somepoint, i will restore it fully. For now i need some parts. Power steering motor seals, rear end seals, water pump (or kit for water pump) clutch pack for torque amplifier. overhaul kit....the list goes on and on....WHERE do i find parts for this tractor. Its our first MM!
First off, you either have a 445 or else a jetstar and you need to know which because it makes a difference sometimes when ordering parts. There is a serial tag on the right side of the transmission case with that info on it. If it starts B1 or A1 or some such post it and somebody on here will tell you what model you actually have.
Welters in MO is good for new parts. 417-498-6496. They also have some used parts, but its kinda hard to get them by phone. probably works better if you are there in person.
Wendell Everett has a large selection of used parts. 740-922-3335 He is not a full time business (he & his brother farm) so it may take more than one phone call.
I do not know if Baucom Imp. in MN is still in business. 1-800-658-2309.
Then
