45 M hydraulic pump
grandpa Love
I drained the chocolate milk out of the pump couple weeks ago and left the plug out to drain. Couple days ago I started pouring oil back in and it runs out around the shaft as fast as I poured it in. Got the hydraulics on the Ford so I will not be trying to use the M for the haybine. Can I disconnect the pump? Easy to do? I don't want to run the tractor and ruin the pump. Will pull pump and fix right next winter in the barn. My dad just wants his tractor running!
Yes the little drive dog can be removed, but since you need the unit moved to get it out you may as well just drop unit out and leave out until repair.
Yes as Slater said it's pretty common to see M's and H's without belly pump so you won't be an outcast driving around without it. Plus then you can work on it on a rainy day before winter.
There is nothing up in the cavity to worry about? Don't need to block off? I guess the 3 pipe fittings come out first?
and the control lever and bakers hat looking fill cap. They are heavy and clumsy. two people of strength and a floor jack are needed. Some use long all thread to replace the bolts so it can be lowered, but that is time consuming. Jim
(quoted from post at 05:10:20 04/05/20) Yes the little drive dog can be removed, but since you need the unit moved to get it out you may as well just drop unit out and leave out until repair.
On an M, that drive dog cannot be removed without dropping the pump.
To remove a belly pump from an H or M, a 4' chunk of 1/2" pipe, several shorter chunks of pipe (with couplings) are necessary. 2 strong men & good strong boy are also needed. Remove all external connections. Unscrew the fill cap. Screw a pipe coupling and a pipe to it that will fit under the gas tank onto the fill cap tube to keep everything going down straight. Put the longer pipe through the opening under the "V" at the bottom of the belly pump. Strong guys now has to be on each side of the pipe. Lift/hold on while the boy removes all bolts. Lower pump to ground while adding pipes to fill tube to keeping things straight. It will help if one can put a pin through the opening & pipe in the center of the "V" in the bottom of the belly pump. The pipe also had to have an appropriate hole drilled prior to inserting into the pump.
I have dropped a lot of those pumps by myself. Floor jack under it, a rod sticking down inside the filler tube to balance it on the way down and let jack down slow. Going up is a little more difficult but in later years we had a floor jack run with air and that worked good to put them in by my self also.
When you work along it is improvise all the time.
Also, I had one m farmall in the shop that clutch would not release. No belly pump in it and the clutch was so full of dirt, grass, corn stalks, you name it as that windmill inside will suck up a bunch of stuff in the right conditions.
