Farmboy1969
I am trying to understand the hydraulic transmission pump to main pump circuit on this tractor.
My front reservoir tank seems to be leaking off and I'm trying to diagnose.
I've been into the relief valve body and checked it out and it seems to be ok.
What has me puzzled is that the transmission pump seems to push into the relief valve body through a check valve and then into the transmission block - I'm assuming through the filter - and then to the line to the main pump.
It would seem that there would have to be a check valve at the filter to keep the oil from just leaking back into the sump through the filter - but I don't see one anywhere in the parts diagrams and can not find in the TM.
I have a labeled picture to post if I can do it.
Any help would be appreciated.
