4630 synchro park
joel rand
I just bought a very nice 4630 but our ground is hilly and I had trouble getting it out of park when facing up a hill yesterday. Is there an easy adjustment or something I am doing wrong?
It's natural. If it won't come out of park, jerk the stick hard enough for it to move then place the it in a forward gear and ease out the clutch. The tran will come out of park.
If load on tran is opposite use reverse instead.
If your tractor is a quad range, it should have a decal on the fender next to the console that shows how to take the pressure off and get it out of park. Basically you would move the spring-loaded ABCD lever to "A". If parked facing down-hill, you would put the Hi/Lo/Reverse lever in reverse. If parked up-hill, you would put the Hi/Lo/Reverse lever in 1 or 2 and then let out the clutch. Vou can actually hear it pop out of park. I think you can also do this on syncro tractors, but it's a bit trickier.
The below descriptions were correct, but I'll add this:
Firmly pull on the shift lever, and put it into the slowest gear to move the tractor UPHILL. Depending on the position of the tractor, this could be 1st, or could be reverse. As you begin to release the clutch, the park release should activate and the tractor will again shift easily.
The purpose of the spring was to help guarantee that the tractor did not jump out of park on an incline.
All good and proper advice.
Some may still wonder however why this works.
The reason it works is because PARK for the synchro range tractors was accomplished by deliberately placing the lower shaft (the one which defines the ranges) in two gears at the same time! As we all know, put a gear train in two different gears at the same time & it is locked up!
The lower shaft is shifted by the left shell in the dashboard's gear shift assembly. This shell's linkage is the one with the spring in it. The spring allows us to move the gear selector to the slow range and then slide the gear shift over to the right shell and there put it into either 1st or lo reverse whichever will take us UP HILL. The lower shaft therefore is still in two gears and the top is now in a third one so in effect the transmission is simultaneoulsy in three gears! That seems a terrible thing BUT.... that third gear will take us UPHILL which will take THE BIND OF GRAVITY off of the lower shaft as soon as you start to let out the clutch! That is when MISTER SPRING snaps into action by shifting the lower shaft into only the LOW range and we're now in either low reverse or 1st gear and headed up hill.
No park pawl or "extra" parts to break this way and park is as beefy as the gear train!
Maybe that helps?
Later.
