I have run into something i have never see before.
I am doing an inframe rebuild on a JD 4450 and i started putting it back together this afternoon. the rods are cast "front" on one side and R71074 on the other. just like any other JD rod. so i put one and six piston sleeve and rod with the arrow on the piston and the cast "front" on the rod facing the radaitor, tourque turn the bolts and turn it over and the rod bolt hits the block on the cam side. so I checked it out and the rod is in backwards. how could this be ?
The big end of the rod has to be towards the cam but then the rod casting "front" is facing the flywheel.
Has anyone seen this before ? am I missing something.
I had someone helping me when I removed the pistons and i was on the bottom. so I didn't see them come out. I looked at the rods on the bench and saw "front" and didn't clean of the top of the piston to see the arrow. i pulled all the pistons and sent out the rods for bushings.
This tractor needs to be chopping corn sunday,
I just drove an hour and got some new rod bolts. and I need to get some sleep. so I would sleep alot better tonight is someone said they have seen a JD rod cast backwards before.
Thanks Ed
Thanks Ed
