466 in 1466
Anonymous-0
going to do the swap to 466...which injectors and cam should i use. Truck or Tractor? any tips or pointers..I already have the 466 tore down to bare block and head and block are going this weekend to get checked Thanks in advance!
Are you going to pull this tractor? If so are going to pull in a farm tractor class that is supposed to be stock? If the answer is yes "the tractor is supposed to be stock" then you would need all ag parts to be right with the rules. If not a stock class the truck stuff works fine.
Does it have the + head and roller lifters?Those would be nice to have.Bigger lines and injecter and a 12 or 13 mill pump will get a easy 300hp.
will need the tractor govenor big difference. i have one in a 560 400 to to 450hp
also go straight to a double clutch
