469 haybine manual
hi i have a old 469 haybine that blew a drive belt an i need to know how to replace it and don't have a manual which manual do i need to get will an owners manual give me directions on how to change the belt thanks
I'm assuming you mean the sickle drive belt, cause that's the tougher one. First,remove the sickle bushing bolt, and remove the three bolts that fasten the wobble box onto the frame from underneath. Be sure to keep track of any shims.
That does the bottom.
For the top, pull off the rear pto shaft. Loosen the idler for the roll drive chains. Loosen the gearbox mounting plate (The whole side plate) and pull it to the left some so you have enough room to work the drive belt over the drive sheave. Bolt'er back up and adjust belts so you get about a 1/4 " of play when you deflect the belt in the middle.
