48 JD A New Manifold Studs
primerk5
Dose anyone know where I can get Manifold Studs for my tractor. Mine are in poor condition so they need to replace. I got them out of the head. I'm thinking I'm probably going to have to make them.
Just an opinion.. available at Deere but are pricey, much cheaper to make your own, or I just use long bolts so if I have to remove it again it comes off without having to remove "other" things. just My suggestion, unless you are a member of the fraternal order of correct police.. which is fine.. its your tractor.
:) I'm not with the correct Police. Though I was going for the correct look. I'll have to think about that it would make things easier if it had to come apart.
So you think that JD still sells them? I'll have to check on JD parts .com. I wouldn't have that they still carried them.
I would venture to guess that deere sells them. external_link.com should also have them. Great people to talk with.
On my 52 A I just used bolts like the numbered series used. It's a lot easier if you ever need to take it off later.
(quoted from post at 09:16:12 10/28/09) Deere still offers them. Front two are part number R2622R ($20.50ea); Back two are part number A2385R ($17.50ea).
Poke here
I knew they were in the catalog. I just didn't think the deere would still be carrying them. Holy cow thats a steep price.
Here is a link to the manifold stud's you want. Scroll about half way down the page. They have the special nuts with the wide shoulders too.
Kurt
Manifold stud for your H, A, and B
On my 48A I used 7/16 bolts, on my 60 I used 7/16 all thread rod and cut it to length then put washers and nuts on top.
Have any of you tried using stainless bolts/studs for the manifold?
I am at the point of putting in the manifolds studs for my 37 B, and I was thinking stainless steel studs would make it easier to take apart in the future.
Kurt
Using bolts where studs are called out has put a lot of folks into trouble. I highly recommend against their use for several reasons. (PatB)
I don’t really like stainless in places like that, it seems like the are more likely to gal up the threads and get stuck and seems the break easier and when they do they are harder to drill out. I used large amounts of high temp antiseize on mine.
I remember reading about never using stainless in cast iron. I dont remember the details, but I would not use stainless.
It should not matter in this application since the late A block does not open up coolant passages to the threads of these bolts.
Using bolts like the numbered series tractors also allows one to remove the manifold from the head without removing the fanshaft.
Bolts will be much easier to find at the hardwares store than studs, and will be 1/8 of the price of the Deere studs.
Call Kevin Stober at Farm Power Restoration. He's got the studs you need...at $6.00 a piece.
610-845-3668
Unless EVERYTHING else on your tractor (ie clamps ,hoses , brake drum rivets , clutch brake pad , wiring , etc,etc are all original then why sweat the stud/bolt thing. Put in bolts.
I always see the argument that cap screws enable one to remove the manifold without taking out first the fanshaft. I grant you that. What I have trouble understanding is why you would "plan" to remove and reinstall the manifold -- as if this were some periodic function you need to perform. Install the manifold properly and forget it!! At least this is my experience. (PatB)
Go to TSC and get some grade 5 bolts. Takem home and cut the heads off at the right length. Chase threads on the cut off end. If you can't chase the threads yourself, take them to a machine shop and have it done. Probably be a lot cheaper. If you're worried about taking it off, leave enough thread on top of the nut for a double nut. Then you can take the studs out and remove the manifold. I wouldn't use bolts. I just went through this on my "H". The reason I wouldn't use bolts is you can't get the torque on a bolt that long like you can a nut on a stud. rw
If you use the tractor as a working machine you can plan on a periodic replacement of repro exhaust manifolds. They crack before the water gets hot. I'm back to using originals with the ears broken off. At least they dont crack.
I did a late A head about 5 years ago and took the measurements to the parts store and they got me new grade 8 studs of the same size. Price was also reasonable.
I have a new manifold to be installed on my '52 'A' when I get time. I have selected Chevrolet head bolts from my collection. They are in different lengths. Look like a perfect fit. I will install the bolts and measure them for sure before I install the manifold. I believe they will work. I'm not saying this is what others should do.
