meterwoman
1972 480C Construction King Loader Backhoe
I need some advice please. My backhoe has a fuel issue that we can not figure out. Any help would be appreciated. When the problem started the backhoe would be running fine then it would cut off like it was out of fuel. It started out a once in a while thing, would cut off, wait a few minutes, it would crank up and run fine, then you could crank it, it would run for a minute then die.
We washed out the diesel tank, changed the filters, got new injectors, spent $1100.00 dollars getting pump rebuilt. Will only run on starter fluid now.now it will only run on starter fluid. We are so frustrated with this backhoe.
