5000 siezed up
Got back at my tractor today to check out my problems. As per suggestions here, tried turning the engine over with a wrench and got nothing...didn"t budge at all. Does that mean I"ve got metal melted together inside or what else can I try?
first thing I'd check is for hyd lock.. IE.. fluid on top of pistons. could be coolant or fuel
pull injectors loose to allow venting, then wrench over to check / verify hyd lock.
post back.
soundguy
Pull injectors and pour in 3oz of 50-50 mix atf and diesel or a 50-50 mix of atf and acetone (or lacquer thinner). Refill every day for a week. Try to turn it over by hand with a big breaker bar after a couple days.
Ok, I'll get at the injectors as soon as I can. This is such bad timing as I am right in the middle of building our house. Once again, thanks for the advice, knowledge and help.
ouch.. could still be hydro lockl or seized crank.. ouch.. both are bad if it stopped it while running...
soudnguy
