5020 engine choice
Have a 1967 5020 John Deere and wondering how much it'd cost to put a 619 engine in it. Guessing this would be much less expensive than a Detroit.
Believe I read you have to move the radiator forward an inch and simply bolt it on. Is this true?
How much more horsepower would this give me and would present radiator be able to keep tractor from running too hot?
Probably never do it. Just wondering.
Don
Hey Doug, You do know of course that that is the Case Magnum engine, how do you think that the Johnny's tranny will stand up to that torque?? mEl
I would tend to think the Screamin' Demon would be cheaper than a 619 Deere engine.... to buy or rebuild. I'd sooner the Detroit anyway if I had to pick between the two. The 619... I thought was one of Deere's poorer engines.
However, if heresy is not a problem to you, put the CUMMINS in it. Then you'd have an engine. Just be sure to get a variable speed govenor if it comes from a truck and has a limiting speed govenor...
Rod
I may be incorrect but I had had the understanding the biggest problem with the 619 was when they used them in the 4x4's, they tied the engine block into the tractor front frame and they had a tendency to crack the block over time because of this. The 619 was used or maybe still is in the self propelled choppers and have not heard many complaints about them around here in that application.
Nothing wrong with a 619 from a forage harvester etc. Just bolt in and go instead of tinkering together some Frankenstein abomination.
I know of a 6030 with a 619 from a forage harvester. The 619 had a bad cylinder when he got it, he fixed it with used parts and ran it for years doing custom work. Also used to clean up with it a the local tractor pulls. Finaly retired the tractor and got a 4640 to get a nice cab. Not bad for a boat anchor.
I never had one and I'm not likely to ever own one because I don't bother much with green things... but I read a lot about them on other forums.
As you say, the FWD issue was the biggest one. Some due to cracking and I think some due to it simply being an inadequate engine for the application... though some will say they have 10K hours on one.
The ones that don't get the hours on them will tell you're they're frightfully expensive to repair... and somewhat given to head/head gasket issues... needing new headbolts, etc.
I've never seen too many comments that would regard the 619 in the same league as say the 404, 414 or 466...
On the other hand, if someone is just playing around with a 5020... the engine choice is probably more about novelty at this point rather than practicality... so it probably doesn't really matter that much.
Rod
5020 has a way overbuilt rear end but the engine was a dog, I plowed for ther neighbor with a 5020 turbo and was never impressed it had zero ft. pounds of torque, if one set an 8.3 at 180 hp and run it with their head I think it would work out fine
