nydolphin
Anyone know what IH calls the seat pivot point, with bolt and rubber bushings, for the seat? Just below where the seat 'shock' is attached. I find no reference to it in the parts section here and locals haven't been able to help me. I've had no problem finding the shock, spring, etc. Mine appears to have a bolt going through the bracket, through the seat and a rubber bushing that goes around each side. All my parts are shot and I have decided, for my safety, to finally replace it.
Thanks for the help
(quoted from post at 11:43:45 09/25/09) Anyone know what IH calls the seat pivot point, with bolt and rubber bushings, for the seat? Just below where the seat 'shock' is attached. I find no reference to it in the parts section here and locals haven't been able to help me. I've had no problem finding the shock, spring, etc. Mine appears to have a bolt going through the bracket, through the seat and a rubber bushing that goes around each side. All my parts are shot and I have decided, for my safety, to finally replace it.
Thanks for the help
This part?
http://www.external_link/IHS585-6-seat-pivot-support-rod
It is possible to use a common bolt and just replace the rubber bushings. Won't look quite the same, but you'll never know the difference.
That looks like the one Rootsy, thanks.
I like your idea Rusty of just replacing the bolt and bushings. It's a work tractor not a show. Thanks
It's the part bottom front. Stud bolt on each side. Case-IH has the parts, just replaced mine. Lots cheaper than I thought.
