I've begun to try to figure out why the tractor is dead. Nothing happens when I turn the key. I had a charger on the battery for several hours.
I had a spare keyed ignition switch and starter solenoid so I replaced those.
I have removed the starter and wirebrushed the metal where the starter contacts the body of the tractor. I have removed, scrubbed shiny, and replaced every connection and cable.
Still nothing.
I don't have a volt meter but I do have an "ice pick" probe. I got a light on most wires with the switch off and a few more with the switch on EXCEPT that I could never get a light from the solenoid to the starter.
I tried shorting across the small solenoid terminal to the large terminal that connects to the starter cable. I suddenly got a loud clicking, plus maybe the sound of the tractor trying to turn over. I did this a couple more times with the same result. To my thinking, if I can get some action by jumping the solenoid, then the new solenoid must be bad, right? So, I decided to put the old one back on. Unfortunately, I can't recall exactly how all the wires hooked up to the solenoid. I found some old pics so I know which way the solenoid should face, and the starter cable should go on the large terminal on the "outside" of the solenoid.
There is a right angled push-on connector that should go to the S terminal.
Do all three of the remaining wires, (battery cable, heavy red wire from ignition switch and another heavy red wire that appears to run to amp meter) go on the other big terminal?
Does the solenoid actually ground to the starter housing, or is it merely mounted there? In other words, does it matter if it's mounted tightly or not?
I'm going to try to reassemble the solenoid and cables the way I think they should go, pending your replies. I'll post back on the results
Still nothing.
